Private Well Filter System - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2010, 05:54 PM   #1
We just bought a home and its my first time dealing with a private well. We had the water tested and I need to find a whole-house filter that can remove lead and VOC's from my well water. Does anyone have any experience with any systems that can do this? I've found a number of filters that attach "under-counter" and I'd rather not do that for every sink/shower in my house.
Thanks for any help!
BigEDGE02 is offline   Reply With Quote
Old 08-16-2010, 06:45 PM   #2
Water Treatment
Rewards Points: 850
Start with a full water test, say Water Check.. with the water straight from the well and not any of the house plumbing.
There are different medias for different items and knowing just what is in the water and at what levels they are will help in finding the right media for the job.
Akpsdvan is offline   Reply With Quote
Old 08-16-2010, 09:42 PM   #3
Thanks for the reply Akpsdvan. I actually had a full test done on both the raw "untreated" water and also the treated water. The only contaminants in the untreated water are the Lead (5.5 ug/l) and Tetrachloroethylene (2.48 ug/l), everything else was shown to be at good levels. The pH is 8.31. The levels all pretty much stayed the same for the treated water.
Old 08-16-2010, 10:36 PM   #4
Water Treatment
Rewards Points: 850
So if I am under standing this right your lead is at .0055ppm?
and the Tetrachloroethylene is at .00248ppm?
Action level for the lead is at .015ppm right?
and action level for the other is at.005ppm?
Is that correct or am I missing something?
Old 08-17-2010, 10:09 AM   #5
You are correct that these levels of lead are below the 15 ug/l action level, however, an "*" at the bottom of my water test report says that:
"The results of a "flushed" raw (untreated) water sample, which is required by the Private Well Testing Act regulations, should be compared to the Ground Water Quality Standard of 5 ug/l found at N.J.A.C. 7:9-6 et seq. The Lead Action Level of 15 ug/l applies to a one liter first-draw tap sample collected from a cold water kitchen or bathroom tap/sink in which the water has remained motionless in the plumbing system for at least 6 hours. This type of standing-water sample is NOT required by the Private Well Testing Act regulations."
I know that when the test was performed, the guy let the water run for about 20 minutes before he took the sample. I guess that is why the report says I should use the 5 ug/l as my benchmark for lead instead of 15 ug/l.
Sorry I forgot to mention all that earlier. I'd still like to bring that lead content down regardless though. Also like to bring the Tetrachloroethylene (PCE) down as well.
Thanks for all your help!
Old 08-17-2010, 11:17 AM   #6
Do a proper test first. From the sample tap on your pressure tank.
Let the water run at least two to three hours first.
Mr. Green is offline   Reply With Quote
May be buying a house -- need some info/advice. greymuzzle Building & Construction 9 10-20-2009 12:25 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
