Price Pfister Shower Only, Not Getting Hot Enough. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2011, 01:26 PM   #1
Price Pfister Shower only, not getting hot enough.
Hello all, and thank you for your time and input.
I have recently remodeled my master bathroom, ( had a licensed plumber do the rough in, as I felt this was one of the areas that should be left to the professionals and not the do it yourselfers. I have also read the 2008 posting of this question & replys, and they helped out with my problem to some degree. However, the Price Pfister valve ( model 0X8/JX8 Series Tub and Shower Valves) stops at the 2 o'clock position, even without the plastic limiter disk, which was set to stop at the 3 o'clock position. The water is warmer now, but not quite hot enough.
Is there a way to make further adjustment(s) to this valve/limiter?
Thank you.
sbeck is offline   Reply With Quote
