Price Pfister Kitchen Faucet 531 Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2010, 09:09 PM   #1
Question
Price Pfister kitchen faucet 531 Help!
Price Pfister faucet 531 series has a T connector for getting the water to the pull down faucet. The instructions say to make sure the end connectors are properly "seated." As best I can tell, I did that and put the clip in place to secure the end connectors. Problem is that water comes out. What am I doing wrong?
mercmanchu is offline   Reply With Quote
Old 01-09-2010, 09:18 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Check the o-rings to make sure you didn't nick them putting it together
Use faucet grease when assembling
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-10-2010, 09:33 AM   #3
Cool
John Wayne...
John Wayne was right. I hate being stupid, but you have to start somewhere. I know that if I keep trying I will gain wisdom. The difference between wisdom and knowledge is experience. Thanks for the help I will take a look.
Old 01-16-2010, 06:32 PM   #4
I just learned something! Was unaware of faucet grease or lube!
reuter is offline   Reply With Quote
Old 01-17-2010, 09:33 AM   #5
Faucet grease
Thanks so much for mentioning this. I am about to install new taps for the first time and like a previous poster had never heard this.
Pontiacgirl is offline   Reply With Quote
Old 01-17-2010, 01:01 PM   #6
Household Handyman
Rewards Points: 1,408
Yes Virginia, there is a special lube for faucets and plumbing O-rings, available at most big box and hardware stores. I use the silicone based, food-safe, comes in a small, round, plastic container, and cost--not much. Do you ever have a faucet that becomes hard to turn from one side of a double sink to the other? By removing the faucet, not the complete assembly, then cleaning and lubing the O-ring and surrounding areas, this will work like new. A lot of hot/cold water cartridges become "sticky" over time and also only need cleaning and a little lube on them. As was posted, some of the newer faucet assemblies have connections with O-rings in them and are not lubed from the factory, which can make life miserable at times installing these. With this plumbers lube--a little dab'l do ya! Thanks, David
Old 01-17-2010, 04:33 PM   #7
Yes you truly are Santa Claus! Thanks for the info.
Old 01-18-2010, 10:33 AM   #8
Solved
The lube grease would have helped. Ended up dissassembling from under the sink. Put it together while standing up and discovered that I had not "seated" it properly. It was not an "O" ring problem. I put it back under and pushed until it kind of clicked into place. It finally worked. I now have the experience and know what to do in the future. Which probably won't happen for another 20 years.
Tags
price pfister faucet 531
