Old 04-30-2012, 10:53 AM   #1
Preventive Maintenance - Swere Rodding
Hi Everyone - I moved into my house 2 years ago and haven't had any issues with the sewer. I live in the suburbs of chicago. My house was built in 1975 and I can't speak of what occurred prior to me moving in.
One of the local companies is having a special listed below for $80. Wanted to get feedback below if this type of preventive maintenance is required? I have the philosophy that i'd rather spend a little money now on maintenance, then have a large problem in the future.
Is there any value in the maintenance below if i've never noticed any sewer issues?
Sewer Rodding Service Includes: Rodding of your main sanitary sewer line from accessible cleanout access with an electric power rod and cutter blade.
Sanitary Sewer Line Televising Includes: Televising of your main sanitary sewer line, this is state of the art technology that allows you to see live footage of the condition of your sanitary sewer line. You will be able to see if your sewer lines are blocked with tree roots, decaying, separated or if your line has broken pipe. Yearly power rodding of your sewer lines will help prevent high cost sewer repairs and/or help avoid a messy, nasty and unsanitary situation!
majch is offline   Reply With Quote
Old 04-30-2012, 09:24 PM   #2
Doing it myself
Alan's Avatar
Well, the theory is that you'll never notice any problems until you have a major one.
In all honesty, if you want to be pro-active, i'd say running a camera to check out the lines would be the least abusive on the lines, especially if they are old.
It wouldn't hurt to do it at least once so that you know where you stand as far as the condition of the lines. If the condition is good, you probably won't need to worry about it for many years.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (05-01-2012)
Old 04-30-2012, 10:49 PM   #3
if built in 1975 you probably have pvc or abs sewer lines. if so it is rare that you would have a root issue due to the pipe being 10 foot sections and glued unlike older clay pipe that was 2 or 3 foot sections held together with cement. the root issue comes in to effect when you get a crack and water starts to seep and the tree roots follow the water and start growing inside and around pipe as they grow it cracks pipe more causing pipe to fill up more until it breaks and collapses
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 05-01-2012, 09:25 AM   #4
I'd go with the cam and only allow them to rod if a problem shows.
Evstarr is offline   Reply With Quote
Old 05-01-2012, 04:25 PM   #5
call me E
TheEplumber's Avatar
80 bucks is a deal, I won't come to your door for that. Get the camera work done. Skip the rodding unless needed. Don't buy anything else without sleeping on it.
Sent from my DROID2 using DIY Chatroom
Old 05-01-2012, 07:19 PM   #6
Well i never believed in this type of service... in the way of preventive mantiance....if home owner is shown cracked tiles....which alot of older homes had....they are forced to replaced sewerline....again if it not broke don't fix it....if you have a problem it will surface....home built in 1975...abs or pvc piping..should not have any problems....don't waste the money....seen so many lines replaced that did not need to be replaced.....ben...
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (05-01-2012)
Old 05-02-2012, 09:51 PM   #7
Master Plumber
Javiles's Avatar
Ben is absolutely correct wait till you have the problem then fix it, we run free cameras after every cleaning because of the warranty we provide and to verify that the line does not have a problem, but only after the blockage. Preventative maintenance maybe the kitchen line if any.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
ben's plumbing (05-02-2012)
AC Not cooling like it should...maintenance guy gives up...help! b1ackcat HVAC 17 08-10-2011 07:22 AM
Toyota Highlander maintenance dinosaur1 Automotive Repairs 10 02-21-2011 02:55 PM
IPE Deck Maintenance Question jason206 Building & Construction 2 02-03-2010 05:36 PM
Preventive maintenance SULTINI HVAC 58 06-04-2009 07:44 PM
hot water heater annual maintenance: a word to the wise diy888 Plumbing 16 03-19-2009 10:59 AM
