Old 12-24-2011, 09:41 PM   #1
Presure balanced valve- can not direct water to shower 100%
I have a presure valve shower/tub which work fine except the water exit to the tub is not totaly stoped when I engage the lever on the water exit - how can I fix this - so water will be directed to the shower head 100%.
Haim is offline   Reply With Quote
Old 12-24-2011, 09:53 PM   #2
We give up, single lever, two knobs, what brand, deverter valve on the tub nozzle, no picture, ect.
ben's plumbing (12-25-2011)
Old 12-25-2011, 09:16 AM   #3
If the diverter is the tub spout, replace it, that is the culprit. But keep in mind that the next one is likely made in china and will be as bad or worse.
Old 12-25-2011, 09:20 AM   #4
ok thanks for the tiny bone...now how about some meat
Old 12-25-2011, 04:49 PM   #5
The diverter valve or some part of it may be worn out, you need to disassemble it. If you are lucky it'lll be fixed when you put in a new gasket or washer or seal.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 06:36 PM
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 05:01 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
