Old 06-15-2011, 05:23 PM   #1
pressure on well
Why is the pressure on my well dropping to 0 pressure when everything is off ? The well is only used for outside use. I can hear what sounds like water running in the well when its turned off and the pressure gauge is dropping.
pnelson is offline   Reply With Quote
Old 06-16-2011, 04:20 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
pressure on well
Soundsd like you have a check valve or a foot valve leaking on the suction (well) side, causing you to lose pressure and maybe prime.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 01:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
