Old 09-05-2010, 10:21 PM   #1
pressure washer on well water
Can I safely use a pressure washer on a low-pressure well water system?
Pressure Washer: 2000 - 3800 gpm
Well water pump: 3/4 hp
Pressure Tank: 32 g (Well X-Trol 203)
Thanks!
Hardly Handy is offline   Reply With Quote
Old 09-05-2010, 10:47 PM   #2
is the input of the PW lower than the gpm of the well? if yes, then yes. if no, then no
the_man is offline   Reply With Quote
Old 09-06-2010, 09:35 AM   #3
Thank you very much, the_man.
I erred --- my Q should say: PWs that output 2000-3800 *psi*!
Sorry!
But you caught that.
Q is, I'd have to look up a particular model's specs to know for sure ...
A PW might advertise, say, a 2.7 gpm capability.
I assume that's referring to usage/output, the same as intake requirement (that is, if my well pump and pressure tank are both capable of at least that 2.7 gpm output, no worries about burning out/busting either?!)?
Thanks again, all.
Old 09-06-2010, 09:16 PM   #4
yea you should be fine. I've never seen a 3 gpm well pump assuming the water table is high enough, normally you'll have at least 10 gpm. 2.7 gpm isn't even a fully open garden hose (half a 5 gallon bucket in one min.)
whole-house water filetration system and water pressure ilyaz Plumbing 4 05-07-2010 03:21 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
