Pressure Valve Leaking After Replacing Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2011, 08:59 PM   #1
Pressure valve leaking after replacing expansion tank
Water heater is about 11 years old. 40 Gal, the expansion tank sprung a leak and I replaced it, had to relieve some pressure from the water heater using the valve. Now there seems to be a repeating discharge from the pipe coming from the pressure relieving valve.
Is that valve bad? I know that some sediments can get lodged so i tried opening the valve for 10 sec to "flush" it, no luck.
Should I replace the valve? Or is this normal? It's never "leaked" before.
Thanks in advnace!
kwando is offline   Reply With Quote
Old 12-14-2011, 09:12 PM   #2
Rewards Points: 582
did you set the tank pressure to match incoming line pressure...and did you check to see if line pressure is greater than 80psi..if it is higher need pressure reducing valve....requirements for tank install...
Old 12-15-2011, 08:55 AM   #3
Rewards Points: 1,452
Empty out the expansion tank before setting the pressure. To do this, turn off the main water valve, then open a hot and a cold faucet upstairs. If needed, pressurize the expansion tank trying to keep it at five PSI until the two faucets stop flowing.
Now follow the instructions for pressurizing the expansion tank. If no instructions then just turn off the faucets and turn on the main water valve.
AllanJ is online now   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Leaking Relief Valve Tobinator HVAC 1 01-16-2011 08:37 AM
Help! Water Heater Pressure Relief Valve leaking mmoore58 Plumbing 4 01-02-2011 01:30 PM
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Hot water tank leaking from valve pipe bookingohio Plumbing 11 05-07-2009 10:43 PM
