Pressure Vacuum Breaker Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2009, 01:36 PM   #1
Pressure vacuum breaker noise
I have a general question. I have a pressure vacuum breaker in the back yard that feeds the auto pool filler. I'm not sure the make/model, but it looks something like this. Also, there is a hose bib I use off of the main line before the breaker.
I've noticed that when it engages, there's a loud noise coming from the vacuum breaker, and it kinda vibrates slightly. It will stop if I cut either line (or reduce the flow a lot) in or out of the breaker. What could cause this? I'm wondering if the whole thing needs to be replaced or if there are some simple things I can check first. One thing I found is the black plastic plate on top is cracked where it's screwed on, but that shouldn't cause this type of noise/shaking. I can't see any leaks coming out of it. Thoughts?
If it would help, I can post pictures of the set up when I get home.
Update:
If it helps, here are some pictures -
scottyja is offline   Reply With Quote
Old 02-06-2009, 11:14 PM   #2
Do you even need something like that? I'd get rid of it.
John McCabe is offline   Reply With Quote
Old 02-07-2009, 01:09 PM   #3
Yes, in AZ at least it's required by law. It prevents contaminated water (such as chlorinated pool water) from going into the main city water line. I guess I'll take it off and take it to the local plumbing store and see what they think.
Old 02-07-2009, 02:00 PM   #4
I would think a simple check valve would be more than sufficient
Harry Homeowner is offline   Reply With Quote
new electric water heater - Vacuum breaker necessary? J187 Plumbing 12 05-26-2012 09:42 AM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
