Pressure Testing Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2012, 09:49 PM   #1
Pressure testing gas line
I finished installing a 250 ft underground gas line from my house to my unattached garage. I pressurized the line to 15 lbs and it held for about 2 plus weeks. (I closed the trench after 3 days and no drop). After one month the pressure has dropped about 5 lbs. (10lbs remaining) The outside temp has also dropped from a high of 100 and a low of 75 to a high of 80 and a low of 55. I was wondering if I should increase the pressure back to 15 lbs or maybe I don't have a problem if some slight leakage is normal and the temp difference had reduced the pressure. Thanks.
Last edited by twiddlebug222; 09-11-2012 at 09:51 PM. Reason: Spelling changes and clarification added
twiddlebug222 is offline   Reply With Quote
Old 09-11-2012, 10:22 PM   #2
Rewards Points: 112
Hmm no expert but I would not want an unknown underground slow gas leak anywhere!
Just me. Did you use a gas liquid leak test on joints? Something simple like dish soap and water? Check for bubbles?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 09-11-2012, 10:26 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Gauge or valve maybe the reason for the drop. pump it up again for 24 hrs then recheck you should be fine.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 09-12-2012, 08:45 PM   #4
Rewards Points: 582
we call that a buried house line....requirements for testing...90psi with a colemen gauge for 10-15 min..
Pressure Testing Gas Line cloves Plumbing 13 04-15-2010 09:08 AM
in line pressure relief valve hidden 1 Plumbing 2 02-22-2009 04:52 PM
Pressure Testing the Filter system, What meter to get? zootjeff HVAC 1 07-12-2007 11:58 AM
Pressure testing methods currious Plumbing 6 04-07-2007 10:37 AM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
