Pressure Tank Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2014, 07:17 PM   #1
Rewards Points: 53
pressure tank size
Hi there Im getting a well drilled in the next two weeks at a cabin. It has one bathroom 1 bedroom and kitchen plus a washing machine. we stay there about 6 days a month. My question is about a pressure tank, Home depot has the flotec tanks on sell for 1/2 price the next 3 days.They have like a 18 gallon 30 gallon 42 gallon and a 80 gallon. My space is limited i can fit up to the 42 gallon one but the 30 would fit better. What size do you think would work best. My well should be less than 200 feet deep and will use 3/4 submersible pump. I would like to buy one on their sell.
thank you
jkoepke is offline   Reply With Quote
Old 03-26-2014, 07:28 PM   #2
Rewards Points: 1,770
The rule is as follows. The larger the tank the less work your pump does.
Old 03-26-2014, 07:43 PM   #3
Rewards Points: 582
the fact you stay there only 6days a month is of no importance..the proper operation of your system is....min size 30 would be ok for your demand..42 would be better ...less work on pump...
Need Help on Well Pressure Tank Layout osubuckeye88 Plumbing 16 02-04-2014 07:02 AM
Well Pump and Water Pressure Tank: Cut-in/Cut-off pressure, pump run time... Trioxide1 Plumbing 15 03-15-2013 11:05 AM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-28-2011 12:30 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Pressure Tank. tropic home Plumbing 2 05-05-2008 08:48 AM
