Pressure Tank Problems - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By jmon
Old 09-07-2016, 05:04 PM   #1
Rewards Points: 2
pressure tank problems
My well pump keeps short cycling, it goes from 30 to 50 psi in about 5 seconds after only letting out about 2 gallons of water. Yet the tank air pressure is holding at about 28 psi. I checked this by killing the power, emptying the tank via the hose bib, then checking air pressure. I even tried letting all the air out of the tank then blowing it back up to 28 psi. So today I replaced the 23 year old pressure switch and gauge and did the same test. Same results.
HOWEVER this time after the pressure switch hit 50 psi I heard a dripping of water from the inside of the tank. Yet the tank is still holding air.
I just don't understand what is going on.
ANY HELP OUT THERE???
charlie y is offline   Reply With Quote
Old 09-07-2016, 05:50 PM   #2
Rewards Points: 218
Re: pressure tank problems
Sounds like the tanks bladder has a rupture in it or scharder valve is leaking. Replace tank would be the next step. Please wait for the plumbers to respond. Thanks.
lenaitch likes this.
jmon is online now   Reply With Quote
Old 09-08-2016, 08:56 AM   #3
Rewards Points: 1,442
Even though the tests you performed so far let you conclude that the pressure tank is emptied of water, there may be lots of water somehow trapped in the tank. This detracts from the space available for the air cushion that maintains the system pressure and results in rapid short pump cycling even when the tank can be repressurized normally. Since you cannot see inside the tank to determine the extent of trapped water, either you need to perform several more complex tests, or replace the pressure tank.
This problem can persist with no measurable let alone audible air leakage outside (use soapy water and check for bubbles) and no measurable let alone visible water leakage outside (use toilet paper which shows water stains quickly).
If the pressure tank leaks air or water to the outside it needs to be repaired or replaced with no further questions asked.
Old 09-08-2016, 10:01 AM   #4
hkstroud's Avatar
Rewards Points: 1,706
Yes, it sounds like you have a ruptured bladder
To properly check for a ruptured bladder.
With the system under pressure, depress the valve stem and let all the air out. Continue holding the valve stem and see if you then get water. If you do you have a ruptured bladder.
To properly set the air charge in a bladder tank you must first completely empty the tank. To simply open a hose bib doesn't do that. The hose bib is usually higher than the tank.
After completely emptying the tank you pressurize it to 2 pounds less than the cut on pressure of the pump switch.
If you have lost the air pressure it is not because of an air leak in the tank. It is because the air (under pressure) is being absorbed by the water.
The dripping you hear is the water moving from the bladder to the tank. The air is between the tank and the bladder. The water is pumped into the bladder.
If you have a ruptured bladder (and you do), you can empty the tank of all water, pressurize it to the proper air pressure. It will then function until the air is again absorbed by the water. How long that will be depends on how much water you use but that will get you by until you can replace the tank.
While draining the tank, pressurize it to push out any water between the bladder and the tank.
hkstroud is offline   Reply With Quote
Old 09-08-2016, 11:36 AM   #5
Rewards Points: 702
When you finally determine the tank needs replacing, I believe you'll find the tank to be heavy with water compared to an empty tank.
The experience I've had is there is a pin hole rather than a golf ball size hole and it took several days, weeks or possibly months for the bladder to become water logged so it doesn't drain in minutes even though water quit running from the garden hose.
Old 09-11-2016, 10:14 AM   #6
If the bladder has only a pinhole in it then the water flow during emptying of the pressure tank is likely to stop short because the bladder hit bottom or herniated into the outlet pipe before all the water got out.
If you let as much of the air as you can out of a bladder tank while the system and pump are still on and you get water out of the air valve then for the reason just above or for a variety of other reasons the system can behave unpredictably until you replace the pressure tank.
A non-bladder pressure tank can be emptied and then all faucets closed and the tank repressurized, and you will get good performance for awhile. You can add air every so often to replace that absorbed by the water if the pump starts running shorter and shorter cycles and then regain good performance.
Well Pump Pressure Problems LTY83 Plumbing 15 06-30-2012 03:58 PM
well pump, pressure tank issue?? fumbrunner Plumbing 2 11-26-2011 09:51 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 10:25 AM
Well Pressure Tank - Maintenance? edro Plumbing 5 12-15-2010 11:23 PM
