Pressure Tank For Jet Pump Installation Request - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 03:05 PM   #1
pressure tank for jet pump installation request
what is the proper way to install a pressure tank for a jet pump (well)?
I think i did mine wrong 'cause the pump shuts off at 10 psi, unless there's another reason why it (jet pump)runs for 5-10 sec and shuts off
Thanks ahead
BOB. is offline   Reply With Quote
The Following User Says Thank You to BOB. For This Useful Post:
mike03 (01-18-2013)
Old 01-18-2013, 03:42 PM   #2
Rewards Points: 14,026
How about you tell us how you installed yours.
Old 01-18-2013, 05:00 PM   #3
joed's Avatar
Rewards Points: 13,358
The tank does not control the pressure of the pump shut off. Your pressure switch does.
Old 01-18-2013, 07:35 PM   #4
yes, but it regulates pressure, otherwise why do we need it?(tank)
Old 01-18-2013, 08:49 PM   #5
It has nothing to do with the pressure.
It's a storage tank so the pump does not have to turn on and off everytime a faucet is opened.
Pressure switches come preset to a low and high limit, the pump should keep right on running it until it hits the high point preset on the switch, did you mess with the switch?
Old 01-21-2013, 04:23 PM   #6
ok,thanks/. Turns out the pump is a 110v , and I had a 220v connected
My bad,sorry
Old 01-21-2013, 05:02 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
My bad,sorry
Ayuh,.... I hate when that happens,....
For what it's worth,...
I've found it don't really matter just Where ya put the pressure tank in the system, nor how Many of 'em ya use....
Bondo is online now   Reply With Quote
well pump pressure without the prime plug? sawduster Plumbing 11 12-19-2012 05:48 PM
replaced pressure tank still no water? Lynn and Bill Plumbing 9 05-07-2012 09:26 PM
well pressure going down/ help bsa_bob Plumbing 5 12-26-2011 02:24 PM
well pump, pressure tank issue?? fumbrunner Plumbing 2 11-26-2011 08:51 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
