Pressure Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2011, 06:49 PM   #1
pressure tank
dose the Amtroll wx203 32gal pressure tank hold 32 gallons in it all the time
dgh1111 is offline   Reply With Quote
Old 02-15-2011, 10:47 PM   #2
no, the 32 gal is the total tank capacity. a 32 gal tank when set correctly (2psi less than pump cuton pressure) holds 10.9 gallons of water when set at 30-50psi, and holds 9.4 gallons when set at 40-60psi.
justwater is offline   Reply With Quote
captive air tank and water pressure bobcatnj Plumbing 6 05-12-2014 09:55 PM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
