Pressure Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2011, 09:02 AM   #1
Unhappy
pressure tank
When I run water my pressure tank kicks on and off every 5 seconds. I tried release some air pressure and water came out of the valve. Is that normal?
davisvt is offline   Reply With Quote
Old 08-20-2011, 09:10 AM   #2
Plumb or Die!
Sounds like the bladder in your tank is hooped.
plumber666 is offline   Reply With Quote
The Following 2 Users Say Thank You to plumber666 For This Useful Post:
oh'mike (08-20-2011), VIPlumber (08-20-2011)
Old 08-20-2011, 09:34 AM   #3
Rewards Points: 161
Your pressure tank is water logged. If it's the type with a bladder you'll need a new tank. If it's the older style without a bladder you need to drain out some of the water and re-pressurize the tank with air.
kb3ca is offline   Reply With Quote
Well tank has no pressure -- PLEASE HELP supitch15 Plumbing 15 02-21-2013 10:00 PM
New Well, Pump & Pressure Tank Design Daneel Plumbing 0 06-07-2011 04:28 PM
Pressure pump cutting in after several minutes of tank emptying Trevor167 Plumbing 2 05-23-2011 09:06 PM
A shared well - do I need a pressure tank upinsmoke Plumbing 9 05-29-2010 04:16 AM
pressure tank problem? steel Plumbing 14 07-03-2008 03:06 PM
