Pressure Switch On Well Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2012, 08:20 PM   #1
Rewards Points: 212
pressure switch on well pump
My son has a leaking pressure switch on his well pump (240V). The switch is SquareD. Just now he found water coming from the switch. He has turned off power, and has headed off to HD to get a replacement.
We have not experienced this before and felt that replacing the whole unit was best. HD closes in an hour so it's a matter of getting a unit and replace.
My question is is there any specific cause other than a leak of some sort on the diaphragm. It isn't rusted out, but there is water in the box as well.
Appreciate any quick advice.
Thanks in advance.
orange is offline   Reply With Quote
Old 03-13-2012, 08:24 PM   #2
Rewards Points: 13,260
That's all you need. Not worth trying to find a new diaphram.
Old 03-13-2012, 08:35 PM   #3
Rewards Points: 212
Thanks very much for the quick response.
Will carry on.
well pump, pressure tank issue?? fumbrunner Plumbing 2 11-26-2011 09:51 PM
Boost Pump for Improved Water Pressure ralphfravel Plumbing 2 08-04-2011 08:33 AM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 02:28 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
well pump wires to pressure switch american501 Electrical 2 12-01-2009 09:13 PM
