Pressure Switch Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2011, 11:09 AM   #1
pressure switch problem
What causes my sq d pressure swith go to the 40 psi cutoff and not do so, causes pump to run and overheqt?
cwbandpab is offline   Reply With Quote
Old 12-02-2011, 03:22 PM   #2
Lightfoot's Avatar
Rewards Points: 272
the contacts could be getting stuck. I had one that started doing that (ran the pressure tank for foamy brush foam at a car wash). It would get stuck. The particular kind i had, you could get a rebuild kit which contained new contacts and springs. I filed the old ones a time or two and that worked for a while, but eventually i ended up rebuilding it. Lasted for another year or two and then i replaced it with a new one. It was the old type, so yours may or may not have contacts. I haven't been in the carwash business for 5 years now, they may not even use the same type anymore.
Lightfoot is offline   Reply With Quote
Old 12-02-2011, 04:10 PM   #3
biggles's Avatar
crap in the switch on the pump side remove it and clean it out....might want to expend it with a nipple and shut off...so you can blow it out
Old 12-02-2011, 07:32 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
No guys....the problem is with the swith....not switch.
The swith is causing the overheqt problem.
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 07:53 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
