Pressure Switch Adjustment For Well Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2011, 03:47 PM   #1
Rewards Points: 127
pressure switch adjustment for well pump
Are there some guidelines for setting the maximum and minimum pressure points on the switch that controls when the pump kicks off and on? I have been experimenting. When the range is too great, taking a shower means waiting through a trickle of water for the next gusher -or- repeatedly re-adjusting the faucets to accommodate changes in pressure.
Thanks,
Daneel
Daneel is offline   Reply With Quote
Old 06-08-2011, 05:17 PM   #2
Household Handyman
Rewards Points: 1,408
This sounds to be a "water-logged" tank problem, not pressure switch. Google "bleeding & charging a well water tank".
Old 06-08-2011, 06:04 PM   #3
Civil Engineer
Rewards Points: 4,854
I agree with Thurman, check out the well tank. As for pressure, typically the setup is cut in at 40 psi, cut out at 60 psi, but you can vary it a few psi either way without too much impact.
Old 06-09-2011, 03:19 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
The pump cut-on/cut-off pressure should be set at 20 pounds psi difference. Usually, a 1/2-hp pump is set at 20-40 psi and a 3/4-hp pump is set at 40-60 psi.
The pressure tank should be set two psi below the pump cut-on pressure.
With the water pressure drained down and the pump off, check the air pressure in the tank with a tire gauge. If it is too high, drain it off just like deflating a tire. If it is too low, air the pressure tank up with a bicycle pump or portable air tank or compressor. If water shoots out of the air valve when testing, the air bladder is shot, so replace the pressure tank.
Some pressure swtiches have two pressure adjustments...a taller threaded one and a shorter threaded one with a nut (one for cut-on, one for cut-off)...or a single one which is factory set 20 psi apart. Raising or lowering the nut(s) with a nut driver or small open end wrench will raise or lower the pressure. Typically, lowering or tightening the nut down will increase the pressure.
If you're adjusting the pressure with the power on, be very careful not to touch the open hot wires. When adjusting a pressure swtich, the pump will kick on and you WILL jump. LOL (I can't help it either.)
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
Daneel (04-09-2016)
Old 06-09-2011, 09:25 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I've also seen this problem before when the tube between the waterline and the pressure switch becomes clogged. Takes longer for the pressure differential to be 'noticed' by the switch. Hence, your low pressure trickle in the waterline.
Do you have a 3/8 or 1/4 brass nipple attached to the switch (submersible pump) or one of those plastic tubes that goes between a switch and a jetpump?
Journeyman Plumber
Boost Pump for Improved Water Pressure ralphfravel Plumbing 2 08-04-2011 07:33 AM
submersible well pump switch? jerryinmich57 Plumbing 7 03-13-2011 03:27 PM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 01:28 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
well pump wires to pressure switch american501 Electrical 2 12-01-2009 08:13 PM
