Pressure Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2012, 08:04 AM   #1
Pressure switch
How do I know if it is the pressure switch that has gone bad and not the pump?
Teresa65 is offline   Reply With Quote
Old 03-31-2012, 08:22 AM   #2
Remodeling Contractor
take the cover off the pressure switch. Use a non-conductive pen and push the contacts in to close them. The pump if good will start. if not the pressure switch may not be the problem. BUT.... the hose between the pressure switch and the tee near the tank may be the issue. I have seen problems where the water in these lines is clogged so the switch is not sensing the proper pressure.
Old 03-31-2012, 08:51 AM   #3
joed's Avatar
Rewards Points: 11,614
Close the switch and measure the voltage on the lines going to the pump. If there is voltage and the pump is not running then the pump or the line to the pump has a problem. If the points on the switch are burnt up simply pushing it closed and seeing if the pump runs is not a valid test.
Old 03-31-2012, 11:52 PM   #4
Rewards Points: 582
yes i agree with you ...if contacts are burnt won't make contact to turn on pump...I would apply voltage direct to pump leads...if it don't start ...you will have to pull pump...
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Well Pressure Switch Replacement (Photos) porkfriedrice Plumbing 4 10-27-2011 05:31 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 08:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
