Pressure Sound In Mains Pipes - Why? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2010, 07:25 PM   #1
Pressure sound in mains pipes - why?
Hi all
am a bit mystified by a background water pressure sound in my mains pipes. A callout service suggested I had a leak under my kitchen floor so I had the kitchen ripped out, tiles up, hole dug in the concrete, but nothing found. As there are no leaks anywhere else (the two cold tanks in the attic are fine) I can only think of the front of the house where I had a hole dug last year to replace a faulty stopcock with a plastic to lead joint so I guess there might be a change in pressure there, but why now?
thanks
ChrissyWissy is offline   Reply With Quote
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 01:04 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Water sound in Pipes Robb Plumbing 14 12-26-2006 11:48 PM
