Old 05-22-2012, 07:19 PM   #1
pressure relief valve at water shutoff
My pressure relief valve started leaking so I replaced it and it still leaks.
swkinv is offline   Reply With Quote
Old 05-22-2012, 08:14 PM   #2
pictures are worth 1000 words...or in your case an answer to your question....
Old 05-22-2012, 09:06 PM   #3
Civil Engineer
Do you have a question buried in there somewhere?
Old 05-23-2012, 01:21 AM   #4
Persona Non Grata
VIPlumber's Avatar
So if the valve is relieving pressure, by leaking, you know it's doing its job. Now if it's leaking because of high pressure what could be the problem? Could it be a waterlogged expansion tank, or a lack of expansion tank altogether? High city pressure? Do you have a pressure reducing valve (PRV), and if so has it failed?
By the way you are talking about the T&P valve coming off your water heater, yes?
So many questions to be answered.
VIPlumber is offline   Reply With Quote
Old 05-23-2012, 10:35 PM   #5
hello where you go
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Pressure Relief Valve right after the Pressure Regulator Asathd Plumbing 0 07-03-2011 03:19 AM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
