Old 05-09-2011, 08:45 AM   #16
Just call me Andrew
pressure relief valve leaks
I think modern indirect water heaters are "tank within a tank" design. Inner tank holds domestic drinking water, under pressure. Outer tank holds boiler water.
If there's a leak in the inner tank, the problem Daniel H. had could exist in your system.
Andrew
secutanudu is offline   Reply With Quote
Old 05-09-2011, 12:19 PM   #17
how
Isolating your heating boiler feed lines to your hotwater tank will tell you if the hot water tank is the problem. Turn the power off to the boiler /turn off the gate valves on the two lines going to your tank/ reduce the psi in the boiler to 20 psi and see if that pressure remains stable. If the boiler is cool and the psi doesn't creep back up you've got a bad tank coil.
If you don't have gate valves on both lines going to your hot water tank then..turn off the power to the boiler/ turn off the domestic cold water gate valve feed line to the hot water tank/ open a hot water tap in the house/ reduce the boiler psi to 20 and watch if it creeps back up.
I tried to post this a few times yesterday but it disapeared twice and I gave up.
Cheers
how is offline   Reply With Quote
Old 06-13-2011, 10:54 AM   #18
I have tried just about everything I can think of and also what's been suggested and the pressure relief valve continues to leak. I have bled the pressure down to 20 psi and as long as the boiler doesn't run it stays constant. As soon as the boiler starts up the pressure begins to increase until it reaches 30 psi and then it drips. Once the boiler shuts off it will drop to about 28 psi and remain constant.
Any more ideas?
f9 flier is offline   Reply With Quote
Old 06-13-2011, 11:14 AM   #19
Any more ideas?
I came across this once - very frustrating. I eventually found out that the bottom port of the spirovent/air scoop where the expansion tank gets screwed-in was clogged with sediment - basically forming a dam such that the expansion tank was rendered useless. I think someone must've used copious amounts of boiler seal liquid to "fix" a leak somewhere in the system.
Drain the system, remove the expansion tank and check that threaded tapping. Make sure it isn't clogged with sediment, scale or "other" (e.g. - coagulated boiler seal).
Ishmael is offline   Reply With Quote
Old 06-14-2011, 09:18 AM   #20
Thanks guys I really appreciate the help.
Old 06-14-2011, 04:58 PM   #21
Does this mean you've figured it out?
Old 06-14-2011, 07:55 PM   #22
Yes I believe it's actually fixed. The domestic hot water heater was the main culprit but the sediment was the last piece to the puzzle. Thanks again for all your help. Couldn't have done it without you guys
The Following User Says Thank You to f9 flier For This Useful Post:
Ishmael (06-14-2011)
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 08:37 PM
in line pressure relief valve hidden 1 Plumbing 2 02-22-2009 05:52 PM
Low Hot Water Pressure NOT the Valve mistervenable Plumbing 1 12-16-2008 11:50 PM
