Pressure Regulators
The maximum recommended pressure is 80 psi, (I don't understand why the 60psi to 120psi spike in pressure) install a pressure reducing valve and also an expansion tank at the water heater. About electrolysis I am not so knowledgeable, and there seems to be varied info on the subject if you google it, but the pitting you describe may be caused by the use of acid based flux, some say it is caused by electrical grounding tied to to water pipes. The recirc line itself should be no less then type L copper as it gets a lot of water flow. Type K is even better.
