Pressure Regulator Malfunction - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2007, 03:26 PM   #1
  • House - Poly Butylene w/ copper rings and fittings - no problem in 15 years.
  • City water
  • Watts Regulator mounted vertically originally (instructions say horizontal)
  • Over night 60 psi leaks up as high as 130. When used, goes back to 60 immediately and creeps up again over 6 hours or so. Originally noticed because gas water heater was lifting pressure relief valve.
  • Replaced 3 times from Home Depot w/ new Watts.
  • Is this due to the mounting? We don't have noticeable sediment.
  • The distance I have to change to horizontal is the length of the regulator, meaning I will have to go 90 out to regulator, then 180 back and 90 again into the house system. Alternative is to use big loops of copper to avoid the 90's.
  • Suggestions? I'd love to find an answer without all the new plumbing - especially if there is something else wrong.
    Thanks!
    Harvey - Norcross, GA.
HRM Dir is offline   Reply With Quote
Old 07-18-2007, 10:10 PM   #2
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
  • City water
    Thanks!
Check the expansion tank on the hotwater heater , the bladder is probably rotted out.
MechanicalDVR is offline   Reply With Quote
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 11:11 AM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
High pressure bjr23 Plumbing 1 03-27-2007 07:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
