Pressure Reducing Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2010, 01:15 PM   #1
Rewards Points: 640
pressure reducing valve
Ok, I had to put a PRV in this past summer because of very high incoming water pressure (110 psi from the street)... of course I put it after the main internal shutoff valve which is after the water meter because there is no room before it and I can't turn off the water outside without the water company... a plumber was over doing some other work, and asked me why the PRV was after the water meter... Then he said "I guess you can't put it before you have no room for it"... should this of been before the meter? I have a tight space constriant here... should I tell the water company their pressure is 110 psi coming in from outside? thanks
BlueBSH is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Pex before pressure reducing valve. rusty_5620 Plumbing 2 03-10-2010 09:16 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
do Pressure Reducing Valve fail? wazeaz Plumbing 5 02-10-2008 05:57 AM
Pressure Reducing Valve duffers Plumbing 5 12-26-2007 04:19 PM
