Pressure Pump Cutting In After Several Minutes Of Tank Emptying - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2011, 06:43 PM   #1
Angry
Pressure pump cutting in after several minutes of tank emptying
Seems I've done everything. Ive adjusted the main screw on the pressure switch, tried adjusting the differential screw also. But the pump will not cut in at the prescribed 20psi. After its tank empties, you stand in the shower, shampoo eating your corneas, soap compounding other issues, for up to 5 minutes before the pump cuts in. Ive checked the thermal protection, so its not the pump triiping off and on. The pressure switch contacts are open. Nothing like the old bucket of water. Any suggestions.
Trevor167 is offline   Reply With Quote
Old 05-23-2011, 07:03 PM   #2
Water Treatment
Rewards Points: 898
The well pump is to start 2lbs under the cut in.. say a 30/50 switch then the pump comes on at 28..
There needs to be 2lbs less of air in the top part of the tank.. if the switch is
40-60 then 38lbs of air
30-50 then 28lbs of air
20-40 then 18lbs of air
The air pressure it taken when the pump is off and there is no water in the pressure tank.
Akpsdvan is offline   Reply With Quote
Old 05-23-2011, 08:06 PM   #3
Thanks, will check it out
Well Pressure Tank - Maintenance? edro Plumbing 5 12-15-2010 10:23 PM
Well Water Pressure Tank for Air? Reilley Plumbing 8 02-20-2009 12:53 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
Pool Motor Wiring Assistance tazmajazz Electrical 18 05-16-2008 10:42 PM
Help me understand my well... Alan Plumbing 5 09-04-2006 07:01 PM
