Pressure Problem In Home Off City Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2017, 09:14 AM   #1
Rewards Points: 4
Pressure Problem in home off city water
I suspect I know the issue here but would like some second opinions.
I have municipal water coming into the home, main water line is 5/8 which goes down to 1/2 after the water meter. Anytime there are 2 things drawing water I have very low pressure.
I think there is just too many taps for the 1/2 line to handle. There are 8 taps in the home total, basement and main level only.
I'd like to run a new 3/4 water line from the water meter to the hot water tank.
Are there any issues having the inside piping a larger size then the water main to the home?
kev6 is offline   Reply With Quote
Old 01-22-2017, 02:20 PM   #2
Rewards Points: 13,978
Re: Pressure Problem in home off city water
If your in the US there is no such thing as 5/8 pipe.
Is it steel pipe?
Steel pipe tends to close up on the inside over the years and will always leak at some point.
http://www.engineeringtoolbox.com/an...pes-d_305.html
A 3/4" pipe will have almost double the avalible flow of a 1/2 pipe, but for the maximum flow rate anything down line would have to be the same or larger.
Adding a pressure tank as well as a larger line may be the way to go.
http://residential.goulds.com/water-...-do-they-work/
Old 02-04-2017, 11:15 PM   #3
Rewards Points: 4
Thanks joecaption
I am in Canada, I did call the town public works recently and they said 5/8 was commonly used 50-70 years ago around here, the house was built in the late 50's. The outside diameter of the copper tubing is 3/4" so I believe the inside is 5/8...
It is a copper main buried water line.
well water pressure problem dmccra012461 General DIY Discussions 10 04-13-2015 03:21 AM
Water pressure problems maddog1 Plumbing 7 11-10-2014 05:37 PM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure YoungRascal Plumbing 8 03-13-2013 05:02 AM
