Pressure Loss Throughout House After Changing Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2011, 09:42 PM   #1
Pressure loss throughout house after changing faucet
I just changed the faucet in one bathroom...I did not shut off our mains, just the inlet valves under the sink. They were off for several hours.
The new faucet is in, nothing is leaking, and the inlets are turned back on. But we have lost water pressure throughout the house. Just a trickle upstairs, and the toilet tanks (up and down) won't refill.
What's going on?
smh73 is offline   Reply With Quote
Old 06-04-2011, 11:19 PM   #2
Rewards Points: 352
Hot, Cold or both have no flow?
If you shut off the same valvas that you shut for the repair do you get water pressure?
plumberinlaw is offline   Reply With Quote
Old 06-04-2011, 11:25 PM   #3
Water Treatment
Rewards Points: 900
Did some one turn off the power to the well pump?
Akpsdvan is offline   Reply With Quote
Old 06-05-2011, 11:30 AM   #4
It eventually came back (~3 hours to get back to normal). Of course, as the pressure came back, the faucet I installed under low pressure sprung a leak and flooded our bathroom while we slept. I shut down the valves and the the pressure has remained normal today. Our city water is occasionally wonky, maybe it was a coincidence. At any rate, unlucky, as I would have left those outlets off overnight if I had known they weren't the problem!
Now I need tips on drying drywall so it doesn't mildew/mold...
Old 06-05-2011, 12:45 PM   #5
Tizzer's Avatar
Rewards Points: 460
Where was your leak?
Tizzer is offline   Reply With Quote
Old 06-05-2011, 12:59 PM   #6
Between the hot water tap and hose--teflon taped it but I guess not tight enough.
Low water pressure in house jdimuzio Plumbing 1 03-21-2011 12:29 PM
House Heat Loss Kirsch Building & Construction 6 12-26-2010 10:58 PM
One side of the house has very poor heat pressure Red Squirrel HVAC 0 10-10-2009 03:16 PM
Water pressure issues - in one part of the house stream41 Plumbing 4 11-11-2008 07:43 PM
