Pressure Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2009, 09:15 PM   #1
Saftety First!
Rewards Points: 77
Pressure leak
I have an LP gas fired boiler, all copper piping, all base board heat.
Four zone control valves with four separate t-stats.
My question is how do I find a pressure leak in the system.
The leak is so slight that it may take weeks or months for the pressure
to drop below the cold pressure limit. But then I have to add water to bring
pressure up again. Needless to say, I have learned over the years how
to drain and re-set the expansion tank. The loss of pressure only
occurs when the boiler is running frequently due to extreme cold weather.
It's a nuisance and also bad for the system to keep adding new water.
So do I need to pressurize the system with air to somehow find the leak?
loyal is offline   Reply With Quote
Old 04-06-2009, 10:30 PM   #2
HVAC / Plumbing
just found that this has been asked on hvac thread
kenmac is offline   Reply With Quote
leak caused by strong water pressure el tigre Plumbing 3 03-29-2009 08:47 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
pressure tank problem? steel Plumbing 14 07-03-2008 03:06 PM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 11:37 AM
