Pressure Drop Across Water Heater, Low Hot Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2011, 06:10 AM   #1
Seasoned DIYer
Rewards Points: 150
Pressure drop across water heater, low hot water flow
I installed a new electric water heater and there is a considerable pressure drop. I'm not sure if it was nearly this bad before, but even with the old water heater, when washer would cycle hot water flow on and off while someone's in the shower, it definitely caused unpleasant cold surges.
Washer faucets are right by the water heater and measuring there, Incoming cold water is ~40psi. It's hardly affected with water use downstream.
Hot water as measured at the washer faucet drops to ~20 psi when shower is turned and pressure read out is very jumpy. Pressure as measured at water heater drain valve is slightly higher.
Pressure at both points read about 40 psi, as expected, with no flow.
Before, I had flexible copper line with same I.D. as normal 3/4" copper pipes. Now, I'm using Sharkbite braided line with I.D. about the same as 1/2" copper line. I don't believe this matters much though. If I bypass the water heater by removing connections at the water heater and connecting the two hose ends, the pressure drop becomes negligible meaning that pressure drop is caused by the water heater itself.
Does this sound pretty normal?
HVAC_NW is offline   Reply With Quote
Old 01-17-2011, 07:15 AM   #2
Rewards Points: 1,512
I would go back to 5/8" or 3/4" inside diameter water lines anyway before doing more pondering and conjecturing.
A 1/4" ID line has about ten percent (theoretically one ninth) the cross sectional area of a 3/4" ID line.
I think it would take a Ph.D. in hydraulics to give a full explanation for your last paragraph.
Old 01-17-2011, 10:43 PM   #3
Seasoned DIYer
Rewards Points: 150
I meant, the ID appears the same as 1/2, not 1/4. That was a typo. It's a SharkBite brand 3/4" braided lines intended for water heater hook up.
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
New Water Heater, worse pressure Repoman75 Plumbing 6 04-15-2005 11:30 PM
