Old 03-30-2008, 11:05 AM   #1
Pressure Balance Shower Valve Hammer
I have a Pegasus pressure balance shower valve has started to act up. I installed it several years ago and it worked fine until it suddenly began to cut-off the hot water and make a hammering noise. As you turn the valve towards full hot, the valve begans to hammer and when you get to full hot it almost completely cuts off the water flow. It makes it very difficult to take a hot (or even warm) shower.
I pulled the spool housing out and cleaned it but nothing changed. I didn't pull the stops out because I didn't know how to readjust them.
Any ideas how to stop the hammering?
glenn60 is offline   Reply With Quote
Old 03-30-2008, 11:14 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Get and install a new spool for that valve.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 04-11-2008, 07:25 PM   #3
I replaced the spool and the cartridge and it still hammers when you turn it to hot.
Old 12-14-2008, 08:30 AM   #4
Hello
I have the same problem as Glenn60. I also replaced the cartige
and the water still hammers when I put on the hot water.
Any sugestions.
Ray
Ray25 is offline   Reply With Quote
Old 01-08-2009, 08:21 PM   #5
I have the same problem with a pegasus valve making a water hammer noise and I also found out that it was a problem with the spool housing (a small cylinder inside that is rattleing around). I replaced it and not long after, the new one was doing the same thing. IT is a pegasus 9200 serries that was purchased at home Depot. anything that anyone knows would be appreciated.
D RAN is offline   Reply With Quote
Old 01-09-2009, 12:31 AM   #6
Sorry guys Im not more help but, it sounds like I shouldn't buy a Pegasus.
integlikewhoa is offline   Reply With Quote
Old 03-08-2009, 08:03 AM   #7
I have the same exact problem. Considering swapping out the cartridge, but it sounds like the valve assembly itself has repeated manufacturing defects or is just a poor design. Anyone able to find a sustainable solution?
Kneedeep is offline   Reply With Quote
Old 06-17-2009, 09:30 PM   #8
I have a Smart Shower Panel. It makes the hammering sound only when I turn on and shut off the hot water. The sound is from the shower panel. I think it is from the cartridge inside the shower panel.
anyone know what is causing it.
dm888 is offline   Reply With Quote
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
New install shower has poor hot water pressure rwhitne Plumbing 2 01-20-2008 05:13 PM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 11:41 AM
Pressure Balancing Valve Installation kpstanton Plumbing 2 03-01-2007 11:30 AM
