Preslope In Tiled Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2012, 01:16 PM   #1
Preslope in tiled shower
I'm renovating my bathroom, which has a 3'x3' shower. I've torn out all of the old material, but I stopped when I got to the drain. I called in a plumber to replace the cast drain trap with PVC so I could use a PVC 3 piece drain. The head plumber and the person who came to do the work today said "no no, you want to lay the shower pan liner directly onto the subfloor, then put a mud bed on top of it. Flat is the way to go."
They're both suggesting the best way is to lay the pan liner on the plywood subfloor, with no preslope mud underneath the pan liner. They said I should add 0.75" of plywood to the subfloor though to make it sturdy. This still doesn't seem right after they explained it to me a few times. It seems the purpose of the pan liner is to be the ultimate catch all for water... so, shouldn't it slope toward the drain weep holes? If I lay it flat, any variation in the sub floor could cause pooling of water in the liner that would never go into the weep holes. Their suggestion would only slope the mud that goes on top of the liner.
Is this a valid way to tile a shower: to not use a preslope under the liner??
gbook2 is offline   Reply With Quote
Old 04-05-2012, 07:46 PM   #2
they were wrong. many have been doing it that way for years tho. do the preslope under the liner and you wont have any problems.
Old 04-05-2012, 07:52 PM   #3
DIY staff
Rewards Points: 7,174
Building a shower pan with pre-sloped mortar bed, liner and curb.
This is the correct method---many pans are build wrong--
framer52 (04-06-2012)
Old 04-05-2012, 09:02 PM   #4
That's the feeling I got. That no-preslope wasn't a bad way to build a shower base, but there are better ways.
Old 04-05-2012, 10:05 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Out of all the people around here that do shower pans, i've only ever seen one guy build a pre-sloped pan.
I'm pretty sure the plumbing code requires that the liner be sloped to drain but i'd have to check on that. Regardless of the validity of my last statement, a sloped liner is a much better idea.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (04-06-2012)
Old 04-06-2012, 06:28 AM   #6
DIY staff
I believe that code only requires a pan to pass a flood test-----
The tile industry and experience tells us that the preslope is needed to keep the pan dry and mold free----
Old 04-06-2012, 07:56 AM   #7
Rewards Points: 528
Mike, your reference was one of the best i have ever seen, thanks for posting it.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
oh'mike (04-07-2012)
Old 04-06-2012, 09:19 AM   #8
Doing it myself
Alan's Avatar
My Oregon residential plumbing specialty code (based on UPC) Says :
411.8 (2)
"All lining materials shall be pitched one-quarter inch per foot (20.9mm) to weep holes in the subdrain of a smooth and solidly formed sub-base."
Journeyman Plumber
Old 04-07-2012, 06:17 AM   #9
DIY staff
Good to see that----
Tags
shower pan installation , video
Waterproofing a tiled shower gbook2 Tiling, ceramics, marble 0 02-03-2012 10:26 AM
Mating tiled wall to fiberglass shower pan? lizardrider Kitchen & Bath Remodeling 6 05-15-2011 01:21 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 01:08 PM
