Prepping For Shower Pan Questions... - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2012, 08:01 PM   #1
Rewards Points: 1,470
Prepping for shower pan questions...
Prepping for a shower pan liner where there once was a small fiberglass shower stall.
1. After I install the ABS/PVC adapter, and the shower drain, what Quikrete product do you guys think would be best to fill the gaping hole surrounding the pipe?
There's a 8" x 8" hole. Slab is 4" thick. Hole is 7" deep.
2. After that task is done, I'll need to do a layer of bedding mud for a pre-slope.
Thoughts on how to ensure that the bedding mud bonds to the raw concrete slab? Or should that not be a concern.
FWIW:
There will be a layer of plastic put up on the walls prior to the Durock. The piece sitting there is just sitting there...
ktkelly is offline   Reply With Quote
Old 06-12-2012, 08:08 PM   #2
DIY staff
Rewards Points: 7,174
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Any type of concrete or mortar will do to pack the hole---I suggest that you pack that with deck mud when you do the preslope---
I would also recommend skipping the plastic vapor barrier and applying a paint on surface membrane
like Red Guard by Custom or Hydroban by Latacrete.
jaydevries (06-12-2012)
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
