Preparing Bathtub Surround For Tiles - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2012, 09:00 AM   #1
Preparing bathtub surround for tiles
Completed gutted my bathroom and have some questions about rebuilding the bathtub surround. I am going to use Durock NextGen backerboard and Versabond white thin set.
1. I plan on tiling the ceiling over the tub. It previously had a dropped ceiling over the old tub that I ripped out, so I now have an 8' ceiling, but I have put up new sheetrock over the entire ceiling of the bathroom. Should I rip out the sheetrock over the tub, where I will tile, and replace that with Durock as well?
2. Durock indicated that I should only put up a vapor barrier on the outside wall, not on the interior walls. I forgot to ask about the ceiling, but I assume that would be considered an "outside wall" as well, which I can do assuming I need to take down the drywall as per question 1. But I have installed insulation as a sound barrier on one of the inside walls. I am thinking I should protect the insulation as well using a vapor barrier.
3. Durock also indicated not to use Redguard, but I see lots of sites recommending it (or something similar), over CBU and the Versabond white thinset should have no problems adhering. Is there a strong reason to not use the Redguard.
bfoglia is offline   Reply With Quote
Old 05-24-2012, 10:37 PM   #2
Rewards Points: 630
need to post in flooring
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-25-2012, 07:24 AM   #3
I actually found the Kitchen and Bathroom forum after posting this in plumbing and copied it there. Couldn't figure out a way to just transfer it to a different forum. Thanks
Tags
backerboard , cbu , cement board , durock , redguard
Question on Bathtub surround and floor Tile Install veesmack323 Flooring 15 02-27-2012 04:01 PM
Ceramic Tile around a Surround Bathtub that has been cut LittleRascals Flooring 1 10-03-2011 01:12 PM
Bathtub Surround dion Plumbing 8 07-28-2010 07:25 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
