Old 07-18-2008, 07:39 AM   #1
jelly's Avatar
Prepare toilet flange - Radiant floor heat
When I roughed in my plumbing, I left the 90 degree 3" elbow an inch above the sub floor. I laid my tubing down and filled around the tubes with mortar. I am 1/2" above the elbow. with the thinset and tile, I will be a good inch above the elbow. Is there a flange or a piece of 3" pvc I shold put in there?
thanks
jelly is offline   Reply With Quote
Old 07-18-2008, 10:19 AM   #2
Doing it myself
Alan's Avatar
thanks
depends on the flange you use, really. The ones we use sit flush with the floor if the 3" pipe is about 1/8 - 1/4 " below the floor, but the pipe inserts into the flange about 1 - 1/4 ".
Best way really is to get the flange you're going to use and measure with it.
Good luck.
Journeyman Plumber
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 10:53 PM
