Old 11-11-2007, 06:11 PM   #1
Default is a pre-slope required for slab shower
We ripped out our old shower and whirlpool tub and are planning to build a shower all the way across the back wall (see red outline in picture below). The plumber has already moved the drains and plumbing. I will be building a shower curb and bench out of pressure treated 2x4s.
Two questions:
1. The plumber is saying that we don't need a a preslope mud bed under the liner. The tile man is going to put a mud bed in on top of the liner but every book/post I see shows that we need a prebed below the liner. Is a pre-bed required?
2. The plumber also says he wants the concrete board attached to the walls before we install the liner (so the liner is not damaged). He says to leave 6 - 8" off of the floor so he can attach the liner to the studs. Again the books I have read say that the liner needs to go in and then the concrete board goes over that. Can it be done the way the plumber says?
memjeff is offline   Reply With Quote
Old 01-16-2009, 05:31 PM   #2
Two questions:
You absolutely need a pre-slope. In most states it is required by building codes. The cement board goes on after and over-lapping the pan-liner. You can't fasten just the bottom pieces of cement board later because you aren't supposed to puncture the liner with fasteners. Pre-slope, Liner, cement board, top layer of dry-pack, then the tile.
Matt C is offline   Reply With Quote
Old 01-16-2009, 08:57 PM   #3
Building codes guy, Mod
thekctermite's Avatar
MattC, although you're 100% right, you're answering a post that is about 14 months old. Happens to the best of us!
thekctermite is offline   Reply With Quote
More On This Topic
Hey everybody, Don Golden here with Expert Village coming to you from my shower. What are we doing in here? I'll tell you what I am doing. I've got a little leak going on and I should be a little bit of an expert on this, fixing showers, fixing leaks... Read More »
So, some of these kits come with a piece of leather that is actually already to the right size and has holes kind of up and down the edges where you'll do your stitching. So that's true for this kind of piece of leather that goes around for this little... Read More »
Installing liners in wood planters saves the planters. Liners keep the planter in excellent condition by protecting it from the effects of watering. If the planters are near a house, porch or deck, the planter liners will protect the surfaces from... Read More »
Now that the paint has dried around our can; which is going to be our drum; we're going to apply those strips that we made with the gold fasteners in them. The way we do that is to apply some rubber cement glue right around the top of the can. We go all... Read More »
Caring for white doves starts before they even arrive. It takes some planning and hard work to build a pen for your white doves. The structure must be safe and secure to protect the white doves from predators and allow them to live and nest productively. Read More »
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 04:58 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 01:12 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 02:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 12:33 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 10:59 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
