Pre-fab Shower Basins - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2010, 12:04 AM   #1
Question
pre-fab shower basins
We tore out a bathtub and want to replace it with a shower. We would like to consider tiling the shower, but as I read about all the steps to prepare the floor from scratch, it seems a bit involved. I'm looking at some pre-fab type shower basins that can be tiled over. Does anyone have any advice as to which products are easy to work with? We are novices, but willing to do extensive research and be well-informed before we start, so we're not afraid to tackle new things.
Also, has anyone worked with the Kerdi shower system? I'd like some feedback on that. thanks, all.
tweetofam is offline   Reply With Quote
Old 09-24-2010, 01:25 AM   #2
definitely use schluter. I will be doing the same.
what type of subfloor do you have?
acerunner is offline   Reply With Quote
The Following User Says Thank You to acerunner For This Useful Post:
tweetofam (09-26-2010)
Old 09-24-2010, 03:37 PM   #3
Just call me Andrew
Rewards Points: 1,020
A couple things to be careful with when using Kerdi...
If you are using concrete board, make the mortar extra wet and/or soak the wall with water before mortaring. Concrete board sucks the moisture right out of the concrete, and since you must use unmodified thinset, it may not set properly.
I recenely had a Kerdi shower done and I am very happy with it aside from one thing - it was the guy's first time using schluter products, and the floor is slightly wavy. Combine that with the fact that the 2" mosaic tiles I picked for the floor have very sharp edges on them. I didn't notice this till after the install, and it forced me to have to put a mat down on my new shower floor due to the old one being uncomfortable to stand on.
So make sure the floor tiles you choose have nice eased edges on them.
Andrew
secutanudu is offline   Reply With Quote
Old 09-26-2010, 02:45 PM   #4
shower basin -Schluter system
Thanks for the advice!
We have 3/4" plywood for the subfloor.
Also, do we have to use the concrete backer board? Does anyone have any advice on this?
Old 09-26-2010, 02:56 PM   #5
Just call me Andrew
From what I understand, you can use drywall with Kerdi. I'd wet the drywall too, maybe not soak it as much as you would concrete board. You just don't want the thinset drying too fast or it won't cure properly.
Andrew
Old 09-26-2010, 03:04 PM   #6
kerdi is completely waterproof. So drywall is fine. I would use green board.
Old 09-28-2010, 09:26 PM   #7
Schluter shower system
One more question - seems like I read a review somewhere on the Kerdi/Schluter shower system where someone said they only last 10-15 years. We really don't want to re-do this whole thing in 10-15 years. Does anyone know anything to confirm or deny that? thanks!
Old 09-28-2010, 09:55 PM   #8
i dont have any cold hard facts. but failures of shower tiling is almost always due to water damage. If schluter does its job in waterproofing, in theory, it should last much much longer. Of course it all depends on a proper installation. So make sure your prep and install is done as instructed in their manual, especially the spec on structural support & subfloor.
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
