Power Vented Water Heater, Powered By A Generator. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2012, 01:27 PM   #1
Power vented water heater, powered by a generator.
We recently installed a power vented water heater, that is being powered by a generator, because it is in a cabin with no other power available.
We can not get it to run, because an error code comes up saying it isn't grounded properly. We have tried a few different things to ground it, with no luck.
Has anyone found a solution to this problem?
Pmmcgillis is offline   Reply With Quote
Old 06-23-2012, 01:46 PM   #2
DIY staff
Rewards Points: 7,174
What brand and model---I don't have an answer for you but one of the plumbers might have run into that same issue.
Old 06-23-2012, 01:56 PM   #3
Rewards Points: 6,652
Here is some info to determine if it is a floating or bonded Neutral on the genset. http://members.rennlist.org/warren/gt5000c.html
Old 06-23-2012, 02:38 PM   #4
MarginallyQualified
Rewards Points: 2,464
Best solution is to return it and install a plain vanilla WH.
Old 06-23-2012, 02:48 PM   #5
Of course there is always the off the grid solutions like solar, or wood fired boiler, that heats water up in a worm, that circulates back to the cabin storage tank. Or use a 100 gallon propane tank.
http://us.yhs4.search.yahoo.com/yhs/...&fr=att-portal
Old 06-23-2012, 03:21 PM   #6
biggles's Avatar
is the generator grounded?then the heater to the gen?
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
Power Vent Water Heater Replacing Draft Vent polebarn HVAC 13 03-28-2012 06:12 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
