-   -   Power vented water heater, powered by a generator. (http://www.diychatroom.com/f7/power-vented-water-heater-powered-generator-148010/)
Pmmcgillis 06-23-2012 02:27 PM
We recently installed a power vented water heater, that is being powered by a generator, because it is in a cabin with no other power available.
We can not get it to run, because an error code comes up saying it isn't grounded properly. We have tried a few different things to ground it, with no luck.
Has anyone found a solution to this problem?
oh'mike 06-23-2012 02:46 PM
What brand and model---I don't have an answer for you but one of the plumbers might have run into that same issue.
gregzoll 06-23-2012 02:56 PM
Here is some info to determine if it is a floating or bonded Neutral on the genset. http://members.rennlist.org/warren/gt5000c.html
TarheelTerp 06-23-2012 03:38 PM
Best solution is to return it and install a plain vanilla WH.
gregzoll 06-23-2012 03:48 PM
Of course there is always the off the grid solutions like solar, or wood fired boiler, that heats water up in a worm, that circulates back to the cabin storage tank. Or use a 100 gallon propane tank.
http://us.yhs4.search.yahoo.com/yhs/...&fr=att-portal
biggles 06-23-2012 04:21 PM
is the generator grounded?then the heater to the gen?
