Old 08-11-2011, 10:02 AM   #1
Question
power vent
Hi working @my dads house in Penna we got a power vent hot water tank the forced air furnace is also pwer vented,can we vent tank into that pvc vent,also we tried to start it up anbd it would not fire up does it need to be vented to start up Thanks Slammer
slammer 3364 is offline   Reply With Quote
Old 08-13-2011, 12:00 PM   #2
power vent
No, you must not tie the water heater vent into the furnace vent, they must be vented separately. Pay close attention to the installation instructions as they will give you clear details for clearances from other vents, air intakes or opening windows in the house. Unless you are trying to collect on an insurance policy for your dad, follow the instructions, and do not "fire up" the water heater without the proper venting in place.
Dougtheplumber is offline   Reply With Quote
The Following User Says Thank You to Dougtheplumber For This Useful Post:
plumber666 (08-14-2011)
Power gable vents VS ridege vent USNavychief Roofing 1 07-15-2011 10:35 AM
Do I need a power vent water heater? bw77 HVAC 1 06-20-2011 06:05 PM
Ridge Vent and Power Vent? etern33 Roofing 7 06-06-2011 08:06 AM
Ridge vent and power vent neikorott Roofing 1 09-09-2010 06:57 AM
Noise from boiler power vent den HVAC 2 03-03-2007 08:10 AM
