Powder Room Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 10:38 PM   #1
Powder room venting
Hi all,
I live in an old house with a single bath on the main floor. I think the plumbing was last updated in the mid-70s. I would like to install a powder room on the second storey. The main stack does not run up through the roof; it stops in the basement and is vented out the side of the foundation. I have attached an annotated photo in hopes that someone can help me out. My plan was to cut in below the kitchen sink pipe and add a 'y' fitting for a 3" pipe that would go up through the floor and make two 90 degree turns before arriving at the flange. From the flange there would be a 3' horizontal run, a 90 degree elbow and a 10 ft or so vertical run, then a 45 degree elbow to the main pipe. I tried to show this in my photo. I thought to us a Studor type Air Admittance Valve, as I believe this is allowed with toilets in my area. Is this possible? Do I need another vent? Have I got too many bends? Thanks a lot for your expertise.
mjordan76 is offline   Reply With Quote
Old 02-25-2012, 10:47 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
You will need to vent the new fixtures at the top floor.
I won't ask why there is a 3" vent thru the foundation- it's not right
Do you know what code is used in your town?
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-25-2012)
Old 02-25-2012, 11:14 PM   #3
Rewards Points: 582
yes agree with e plumber..you will need to vent on top floor....not sure about aav on a commode...don't seem right but then again neither is that 3" vent out the side of house....adding pr is ok ..just up grade plumbing to someones code...ben
Old 02-26-2012, 09:19 AM   #4
Rewards Points: 636
here they allow aav on toilets as long as you have one vent going to the out side
just click on the different codes at bottom to read all aav codes
http://publicecodes.citation.com/ico...2_9_sec018.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
ben's plumbing (02-26-2012)
powder room drywall amakarevic Drywall & Plaster 3 05-21-2011 05:10 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
Painting room finally Imkindofbigdeal Painting 10 03-16-2011 04:22 PM
Boiler room venting dontilgon HVAC 19 12-07-2009 06:07 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
