-   -   Powder room venting (http://www.diychatroom.com/f7/powder-room-venting-135046/)
mjordan76 02-25-2012 09:38 PM
Powder room venting
1 Attachment(s)
Hi all,
I live in an old house with a single bath on the main floor. I think the plumbing was last updated in the mid-70s. I would like to install a powder room on the second storey. The main stack does not run up through the roof; it stops in the basement and is vented out the side of the foundation. I have attached an annotated photo in hopes that someone can help me out. My plan was to cut in below the kitchen sink pipe and add a 'y' fitting for a 3" pipe that would go up through the floor and make two 90 degree turns before arriving at the flange. From the flange there would be a 3' horizontal run, a 90 degree elbow and a 10 ft or so vertical run, then a 45 degree elbow to the main pipe. I tried to show this in my photo. I thought to us a Studor type Air Admittance Valve, as I believe this is allowed with toilets in my area. Is this possible? Do I need another vent? Have I got too many bends? Thanks a lot for your expertise.
TheEplumber 02-25-2012 09:47 PM
199 Attachment(s)
You will need to vent the new fixtures at the top floor.
I won't ask why there is a 3" vent thru the foundation- it's not right :eek:
Do you know what code is used in your town?
ben's plumbing 02-25-2012 10:14 PM
yes agree with e plumber..you will need to vent on top floor....not sure about aav on a commode...don't seem right but then again neither is that 3" vent out the side of house....adding pr is ok ..just up grade plumbing to someones code...ben:yes:
jaydevries 02-26-2012 08:19 AM
here they allow aav on toilets as long as you have one vent going to the out side
just click on the different codes at bottom to read all aav codes
http://publicecodes.citation.com/ico...2_9_sec018.htm
