Pouring Hot Water And Dish Soap To Unclog A Toilet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2013, 06:30 PM   #1
Pouring hot water and dish soap to unclog a toilet.
Good idea?
Bad idea?
Hardway is offline   Reply With Quote
Old 05-16-2013, 06:47 PM   #2
Rewards Points: 14,312
Waste of time.
Any other drains running slow?
Have you pluged it with water in the toilet?
Have you removed the toilet and ran a big snake down the drain?
Used a closit auger to checked to see if it's the toilet that's plugged up and not the drain?
Removed the clean out under the house to check for a plug?
Old 05-16-2013, 06:52 PM   #3
Rewards Points: 358
Never heard of it before. I always just plunged it. Apparently it's a pretty good idea. I was reading this link. Next time I will try the hot water first to help disolve the clog see if that helps. Thanks for the tip
hot water and dish soap link
jmon is offline   Reply With Quote
Old 05-16-2013, 06:57 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Ever heard of a plunger ??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-16-2013, 07:11 PM   #5
Hot water and soap is not going to desove poop or toilet paper or whatever else go flushed down.
Might be fine for a kitchen sink, not a toilet.
Old 05-16-2013, 07:15 PM   #6
Originally Posted by joecaption View Post
Waste of time.
Joe thanks for the response with how to help. I don't have a clog, but I am well versed in un-clogging drains.
I read a link on facebook about using hot water and dish soap.
I would think pouring hot water in a cold toilet bowl would not be a good idea.
Old 05-16-2013, 07:18 PM   #7
Originally Posted by jmon View Post
Never heard of it before. I always just pluged it. Apparently it's a pretty good idea. I was reading this link. Next time I will try the hot water first to help disolve the clog see if that helps. Thanks for the tip
Thanks jmon I was not able to copy and paste the link.
Old 05-16-2013, 07:40 PM   #8
Rewards Points: 358
Hardway, good point. The link actually said use warm water not hot boiling water.
Old 05-16-2013, 09:56 PM   #9
Rewards Points: 2,110
A toilet auger works wonders also.
Old 05-16-2013, 10:13 PM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,086
There's a trick to using a plunger, most people have no idea how to actually use them (this includes my wife).
Hot water seems like a bad idea to me, but i'd never need to go that route.
Journeyman Plumber
Old 05-17-2013, 07:38 AM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 996
So true,
Old 05-17-2013, 08:01 AM   #12
Roofmaster
Rewards Points: 2,210
[QUOTE=Alan;1180917]There's a trick to using a plunger, most people have no idea how to actually use them (this includes my wife).
There sure is, thats why people that know their function call them force pumps, not plungers. Go Alan.
Water in our toilet bowl sucks out? Bluwolf Plumbing 6 04-23-2011 09:23 PM
Dish Water Silent after being in Drydock clemkonan Appliances 0 07-10-2010 09:58 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
Hot water temp.or bad soap deck hand Plumbing 11 05-30-2008 09:21 PM
