Pouring Concrete Around Cast Iron Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2009, 10:59 AM   #1
pouring concrete around cast iron pipe?
Are there any special requirements for pouring a concrete slab around a cast iron pipe that rises vertically?
Such as using isolation material?
walkman is offline   Reply With Quote
Old 10-16-2009, 11:04 AM   #2
Since concrete can still move, I have always isolated the pipe from the concrete. Some use styrofoam and others use foam rubber insulation. I have also seen a box frame built around the pipe and when the slab dries, the box is made into a separate pour. This allows a little movement.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
Porcelain Quality on Steel and Cast Iron Tub? MrTubz General DIY Discussions 5 03-04-2009 06:24 AM
Identifying size of Black Iron Pipe jamiedolan Plumbing 2 10-06-2008 01:39 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
