Poured Cement Around Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2011, 04:25 AM   #1
Poured cement around water pipe
After repairing the sewer pipes I replaced the cement in my basement floor. During this process I covered the opening to the foundation that housed both my sewer pipe an water pipe leading out of the house.
Was this a mistake?
Rp23 is offline   Reply With Quote
Old 06-16-2011, 07:48 AM   #2
Don't understand the question, they are usually buried, and always accessible with a jack hammer.
Old 06-16-2011, 11:32 AM   #3
Typically, you want to sleeve the copper with something. It will most likely become a problem many years down the road as the lime in the concrete slowly eats away at the copper.
Ishmael is offline   Reply With Quote
Old 06-16-2011, 04:46 PM   #4
Rewards Points: 410
I've never seen them being accessible with a jack hammer every house I know they have a removeable cover. You're in a world of hurt probably if they do have to use a jack hammer and cemented it in (vs. covering it completely in sand and then pouring the concrete).
They're left exposed with a cover for a reason. Typically because tree roots have grown into the pipe and plugged it a plumber would run a device to cut the roots out down that opening. In my case my sewer wasn't working right and the plumber put a camera down the pipe at that location and we found a dip (probably a sink hole).
I've never seen them cemented in, I would opt it was a mistake. I'm thinking back and remember my father and neighbor had a plumber cut roots out using that opening, and me with my sewer pipe that dipped.
Piedmont is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
basement wall waterproofing Jenbarkel Building & Construction 9 08-30-2010 06:37 PM
hot water pipe under the cement leaking befuuddled Plumbing 3 07-02-2009 03:58 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
