Potassium Water Softener Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2009, 01:00 PM   #1
Potassium water softener problem
I have a Rainsoft water softener that uses potassium pellets. Several months ago it stopped working b/c the potassium solidified at the bottom of the unit, with water on top of it. I tried to break it up manually but that proved too diffficult. Is there a way to dissolve it?
Darlok is offline   Reply With Quote
Old 02-02-2009, 02:04 PM   #2
Water quality'n pump guy
Breaking it up with a ground pin or other type steel bar (don't poke a hole in the bottom of the tank or the salt gird if you have one [that's a false bottom in the salt tank]) is usually the quickest way to clean the tank out but, MANY gallons of hot water over a number of hours, will dissolve it but, it also will make the tank weak because it is plastic.
Gary Slusser is offline   Reply With Quote
Old 02-02-2009, 06:08 PM   #3
I second the hot water but pottasium sets up like a rock. The best way to not have that problem ever again is to fill up the brine tank and let it go almost completely empty before putting anymore in. get rid of the old before you put in the new.
lilh2o3 is offline   Reply With Quote
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 06:42 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
recirculating hot water problem cliff Plumbing 3 08-20-2007 11:40 AM
