Potable Compression Fittings For Pex-al-pex? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2011, 07:20 AM   #1
Rewards Points: 81
Potable compression fittings for pex-al-pex?
Hi, I'm looking to install a hydronic heating system. It's going to be an "open" system, wherein the water for the heating mixes with the potable hot water supply to some degree.
I'm almost convinced to buy a press tool, but I'm considering compression type fittings.
The trouble is, none of the pex-al-pex compression fittings I'm finding are listed for use with potable water.
Know of any brands?
-Jeff
mysterylectric is offline   Reply With Quote
Old 02-07-2011, 10:34 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,056
Ayuh,... I suggest you reconsider that thought...
Potable water should Never mix with heating water....
Toxicity of the fittings is the least of your problems ...
Bondo is online now   Reply With Quote
Old 02-07-2011, 03:11 PM   #3
Rewards Points: 81
Hmmm, the installation manual for my (tankless) water heater makes it seem pretty straightforward. I know that another concern is that most zone valves (seal materials) aren't rated for fresh water. I'm not going to use zone valves per se, I mean to use three-way valves at each baseboard unit: each unit is either "cut in" to the loop or bypassed. I think I have the scalding issue covered.
What else might go wrong?
-Jeff
compression fittings on copper pipes Gabriel24 Plumbing 17 10-21-2010 10:28 AM
Compression Fittings HollandAce Plumbing 3 08-14-2010 06:52 PM
Pex tubing & compression fittings Ultrarunner2017 Plumbing 2 02-11-2009 07:51 PM
Pex Tubing on Compression Fittings handy man88 Plumbing 3 01-24-2009 08:30 AM
Metric compression fittings ??? rutalkn Plumbing 3 11-27-2007 10:43 PM
