Old 11-08-2006, 10:44 PM   #1
Pot filler length
I am considering adding a pot filler above my new range. I am installing a 48" gas range with griddle and grill on one side of it(1/2). I was wondering what length pot filler arm I will need to use it with this range?
wbjdmd is offline   Reply With Quote
Old 11-09-2006, 05:43 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Pot filler length
Read the specs on the pot fillers, you decide, all depends on what you want.
Ron The Plumber is offline   Reply With Quote
Old 11-09-2006, 07:20 AM   #3
Pot filler length
They do make them that are two piece so it can fold up to the wall or be extened out to reach across you stove
clasact is offline   Reply With Quote
Switch/Toggle Plate Filler stavros516 Electrical 4 03-25-2007 03:22 PM
Is it OK to tape by multiple pieces of tape on one length? KUIPORNG Remodeling 3 01-21-2007 01:17 PM
Using fiberglass filler on a balcony darsunt Painting 2 12-31-2006 09:13 PM
Filler loop under combi bolier Sheza58 HVAC 2 12-29-2006 07:43 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 11:50 AM
