Pot Filler Above Stove - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2013, 06:50 AM   #1
DIY staff
Rewards Points: 7,174
Pot filler above stove
I have a customer that wants a pot filler above her stove---
I have installed these in restaurant kitchens--those were hot and cold---
Are the residential ones only cold water?
A Google search showed only single feed faucets.---Mike-----
Old 08-22-2013, 07:21 AM   #2
Rewards Points: 14,026
While it's possible to buy wall mounted hot and cold faucets it would look clunky in my option.
Why not just plumb it for just hot water?
Never did really understand the need for one in a residential setting.
You still have to lift a pot of boiling hot water to drain the pot.
Seems like one of those things that looks cool and sounds like a good idea at the time.
http://www.bing.com/images/search?q=...chen&FORM=IGRE
Old 08-22-2013, 07:54 AM   #3
Yes pot fillers should be installed with a cold water supply only.. Most ho have hot water tanks and these tanks build up sediment and dip tubes are rarely changed allowing accumulation, if its piped into the hot line these particles can make their way into the pot hence the reason not too pipe a pot filler on the hot side..
Peppe1019 is offline   Reply With Quote
The Following User Says Thank You to Peppe1019 For This Useful Post:
oh'mike (08-22-2013)
Old 08-22-2013, 08:33 AM   #4
MarginallyQualified
Rewards Points: 2,464
They're made with mixing faucet base and they're made without any faucet at all (remote located faucet)... but I've never seen or used or sold anything but a single cold supply.
http://www.tsbrass.com/products/b-05...filling-faucet
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 08-22-2013, 08:41 AM   #5
bbo
they do make the dual handle ones, but I prefer the single handle ones.
I'd think it would be rare that you NEED to have hot water on hand to initiate cooking some item on the stove. Plus, without researching it, I'd think hot water might be inherently not as safe as starting with cold. I.E. hot water leaching things from piping and solder, water heater tank may have rust or sediment in it, etc.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 08-22-2013, 10:06 AM   #6
Lightfoot's Avatar
Rewards Points: 272
The one's i recently saw in a "parade of homes" tour, were just one single faucet. Cold water feed.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 08-22-2013, 10:41 AM   #7
Copper and solder do not leach into hot water and all these componets are approved to bring potable water to a home if it was prone to such it would not be approved for potable use..The reason i posted is why to not use hot water to fill a pot water heater and thats wh tank debris....
Old 08-22-2013, 11:18 AM   #8
bbo
I figured someone would reply and I'd then do some research
quote "The principal source of copper in drinking water
results from the leaching of copper from pipes and bath fixtures due to acidic water."
from
Actually seems coppper might be beneficial.
and this .. right from EPA.gov ( I would guess this mostly applies to older homes )
quote" Flush your pipes before drinking, and only use cold water for cooking and drinking. "
http://water.epa.gov/drink/info/lead/lead1.cfm
I guess for me, my initial instinct to use initially cold water would be best for me. of course, your own mileage would vary. I'm sure if I looked hard enough, I could find a study showing hot water is perfectly fine to cook with. And with my newer home, its probably not much of a concern at all, if any.
Old 08-22-2013, 11:53 AM   #9
Good research and i do agree with using cold water for cooking and drinking but if we took the epa's word at face value than exhaling would be a fineable offence for producing too much emissions...only reports ive seen on leaching were from pex and it being exposed to uv,petroleum based products etc...
Old 08-22-2013, 07:08 PM   #10
DIY staff
I set it up for a double handle hot/cold restaurant tap with 8" centers.
The homeowner has arthritis in her wrists----(and it does have a certain COOL factor)
I'm with you on the cold only---without a drain--you can't run the water long enough to get hot water before a pot is filled--
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Help with adding custom color to wood filler 4thDimension Carpentry 5 10-14-2011 01:46 PM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
