Old 01-31-2013, 08:27 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Possible to put utility sink here?
What do you all think?
The bottom of that trap is 10" off the ground and the top of it (where it goes into the other pipe) is 15" off the ground.
The first pipe (left) is the washing machine, the middle is the kitchen sink and the right one is the vent.
CoconutPete is offline   Reply With Quote
Old 01-31-2013, 08:32 PM   #2
call me E
TheEplumber's Avatar
Yep- it should replace the washer though.
Be ready for a bunch of guys to tell you to replace the old pipe
Old 01-31-2013, 08:33 PM   #3
Master Plumber
Javiles's Avatar
NOT ME !!!
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
TheEplumber (01-31-2013)
Old 01-31-2013, 09:32 PM   #4
Above the concrete? Or are we talking jackhammer?
A simple cutting job I can handle but if I am jackhammering I may have to postpone.
Old 01-31-2013, 09:47 PM   #5
Man, replace that old pipe above the slab
paintdrying is offline   Reply With Quote
Old 02-01-2013, 09:56 AM   #6
So the washer should discharge into the sink and the sink should have a pump that dumps into the pipe the washer was discharging into?
Anything else to add? Like ... use a saw and cut it flush to the floor or .... use a torch and try to pry it out at the bottom fitting or ..... cut it x inches above the floor?
Old 02-01-2013, 03:09 PM   #7
This is how everything ties into the kitchen above if that helps. Please ignore the giant lead pipe drain, it has been replaced by now.
Old 02-01-2013, 05:53 PM   #8
That lead pipe drain needs to go as well
Old 02-05-2013, 08:37 AM   #9
Here is what I arrived at. Don't mind the horrendous photoshop skillz.
Old 02-05-2013, 10:27 AM   #10
Doing it myself
Alan's Avatar
Pete : If you say that bottom trap is 10" off the floor, I assume by your photoshopped image that the drain outlet for the sink is too high. Most utility sink basins are very deep and if you're much higher than 16" you're going to have a problem hooking it up.
If I was you, i'd try to remove everything there down to the lowest hub at the concrete. Leave the hub of course. Use a fernco "Donut" (google it) to adapt your cast iron hub to sch 40 pvc or abs (whichever you prefer). Your abs/pvc fittings will be a lot more compact than those others, and everything should fit together nicely. Remove as much of that kitchen drain as possible to alleviate the weight of the heavy metal bearing down on a plastic fitting.
Journeyman Plumber
Old 02-05-2013, 10:55 AM   #11
call me E
A washer should be on a 2" line- it would be best if you could tie into the base of the kitchen line and leave the re-vent as you show.
The laundry sink is ok the way you have it- just lower it like Allen suggested.
Need utility sink drain help mkerns12 Plumbing 7 01-05-2013 01:40 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 09:10 PM
Installing Utility Sink newb Plumbing 2 02-05-2010 01:35 AM
Converting utility sink to standpipe? thebigsee Plumbing 7 08-17-2009 11:06 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
